Getting your first withdrawal right is the real test of any iGaming platform — this guide shows you how to pass it. Whether you’re a new player or an experienced high roller, mastering the withdrawal process ensures your winnings reach you without unnecessary delays.
What You Need First
- A fully verified account – complete KYC (Know Your Customer) by uploading a valid ID, proof of address, and proof of payment method.
- Sufficient cleared funds – bonuses often have wagering requirements that must be met before withdrawal.
- Identity documents that match your registration details exactly (name, address, date of birth).
- At least one active payment method – same method used for deposit is typically required for the first withdrawal.
- A stable internet connection and a device with a modern browser – the platform is mobile-optimized and works as a progressive web app (PWA).
- Understanding of any applicable withdrawal limits and processing times for your chosen method.
Account Setup
- Visit Spinboss casino and click the “Sign Up” button.
- Fill in the registration form with your personal details – use exactly your legal name and current address.
- Choose a strong password and enable two-factor authentication (2FA) for extra security.
- Verify your email by clicking the link sent to your inbox.
- Log in and navigate to the “Account” or “Profile” section to complete KYC verification. Upload clear photos of your ID, a recent utility bill, and a selfie holding your ID.
- Once verified, make your first deposit using a method from the cashier. Wagering requirements apply to any bonus you claim.
Wagering Calculation
Understanding how wagering requirements work is crucial to converting bonus funds into withdrawable cash. Let’s break it down with a real example.
Example: You deposit $100 and receive a 100% match bonus worth $100. The bonus has a 35x wagering requirement on the bonus amount only (common for many casinos). You must wager $100 × 35 = $3,500 before withdrawing any winnings from the bonus.
If the requirement is on deposit + bonus (e.g., 30x), then you need to wager ($100 + $100) × 30 = $6,000.
Formula:
Wagering Required = (Bonus Amount × Wagering Multiplier) or (Deposit + Bonus) × Wagering Multiplier.
Your contribution to wagering depends on the game. Slots usually contribute 100%, table games often contribute only 10-20%, and some games like poker or baccarat may contribute 0%.
Let’s say you play only slots (100% contribution) and you bet $5 per spin. Number of spins needed: $3,500 ÷ $5 = 700 spins. If each spin takes 3 seconds, that’s about 35 minutes of play (700 spins × 3 seconds = 2,100 seconds = 35 minutes). But remember, you also have to meet the wagering within the bonus validity period (usually 7-30 days).
Tip: Always check the terms for the maximum bet allowed while wagering (e.g., $10 per spin) – exceeding it may void the bonus.
After wagering, your bonus balance becomes real money. Then you can proceed to withdrawal.
Security
Casino security relies on SSL encryption (256-bit) to protect data transmission. Account security is enhanced by 2FA – enable it in your profile settings. For withdrawals, the casino may request additional verification, such as a video call or signed declaration, especially for large amounts. Always use a secure, private internet connection when accessing your account. Never share your login credentials.
Payment Methods
| Method | Deposit Min/Max | Withdrawal Min/Max | Processing Time | Fees |
| Visa/Mastercard | $20 – $5,000 | $20 – $5,000 | 1–3 business days | None by casino |
| Skrill | $10 – $10,000 | $10 – $10,000 | Up to 24 hours | None |
| Neteller | $10 – $10,000 | $10 – $10,000 | Up to 24 hours | None |
| Cryptocurrency (Bitcoin, Ethereum) | $20 – $10,000 | $50 – $10,000 | Instant – 1 hour | Network fee may apply |
| Bank Transfer | $50 – $20,000 | $100 – $20,000 | 3–5 business days | Possible bank fee |
Note: Withdrawals are usually processed to the same method used for deposit. If that method doesn’t support withdrawals (e.g., some prepaid cards), an alternative will be offered.
Fix It Fast
- Situation 1: Withdrawal pending for over 48 hours.
Check if your account is fully verified. If not, complete KYC. If verified, contact live chat and ask for an update. - Situation 2: Withdrawal rejected.
Review the reason: usually due to unmet wagering requirements (check bonus terms), exceeded withdrawal limit, or mismatch in payment method. Correct the issue and resubmit. - Situation 3: Cannot select withdrawal method.
You may need to make a deposit using that method first. Deposit a small amount and then request withdrawal. - Situation 4: Withdrawal amount less than expected.
Check if there are any fees applied or if you had an active bonus that converted only part of your balance. Also see if a maximum cashout cap applies to bonus winnings. - Situation 5: Timeout errors when submitting withdrawal.
Clear your browser cache, disable ad-blocking extensions, or try a different browser/incognito mode. If the issue persists, contact support.
Extra Tips
To maximize your chances of winning and reduce the house edge, focus on games with high RTP (Return to Player). Slots with RTP above 97% are ideal – look for titles like “Mega Joker” (99%), “Blood Suckers” (98%), or “Starmania” (97.9%). Table games like blackjack (optimal strategy gives RTP ~99.5%) and video poker (e.g., Jacks or Better with 99.5% RTP) are excellent. Avoid progressive jackpot slots (often RTP below 90%) unless you’re specifically chasing the jackpot. Also avoid keno and bingo as they tend to have high house edges.
Common Questions
How long does a typical withdrawal take?
After approval, e‑wallets usually take up to 24 hours, card payments 1–3 business days, and bank transfers 3–5 business days. Cryptocurrency withdrawals are often processed within an hour.
What documents are needed for verification?
You need a government-issued ID (passport, driver’s license), a recent utility bill or bank statement (address proof), and sometimes a photo of your payment method (with digits masked) or a selfie holding your ID.
Is there a maximum withdrawal limit?
Yes, typical monthly limits range from $10,000 to $50,000 depending on your VIP level. Check the terms for specific caps.
Can I withdraw my bonus winnings immediately?
No, you must first meet the wagering requirements. Once wagered, the bonus amount becomes real cash and can be withdrawn minus any bonus amount if required.
What happens if I withdraw my deposit before wagering?
If you withdraw before fulfilling the wagering requirement, you forfeit the bonus and any winnings generated from it.
Are there any fees on withdrawals?
The casino does not charge fees, but your payment provider or bank may charge a fee. Cryptocurrency withdrawals may incur network transaction fees.
Can I cancel a pending withdrawal?
Usually yes, as long as it hasn’t been processed. Go to the cashier, select pending withdrawals, and cancel. The funds return to your account.
How do I know my withdrawal is approved?
You will receive an email notification, and the status in your account history will change from “Pending” to “Approved” or “Completed”.
What if I have a problem with my withdrawal?
Contact customer support via live chat or email. Provide your account ID and details about the issue. They usually respond within 24 hours.
By following this step-by-step guide, you can navigate the withdrawal process with confidence. Remember to always verify your account early, read bonus terms thoroughly, and choose a payment method that matches your needs. With careful planning, your first withdrawal will be a smooth and rewarding experience.
